I tried to purchase a switch for a reciprocating saw with variable speed for my Dewalt DW304. I discovered the part is no longer available.
Instead, I bought a similar switch used on the later model DW304PK. Its electronic, however, baffles me. The original one has a switch housing a simple DIAC circuit for triggering an external TRIAC, but the new one a more complex SCR circuit.
Below is my shoddy attempt at a schematic. I was able to read values from what I believe to be diodes, capacitors and resistors. The black strips are resistors. The two longer ones are slide resistors (?). I was unable to obtain a datasheet for it, but the make is Marquardt and the part number is 2069.0504. The SCR is a TN1215.
I was under the impression that an SCR throws away half of the voltage, whereas a TRIAC uses the full voltage. Is there a good reason why the manufacturer would use a SCR circuit when you are only getting half the power? For machines designed to cut metal, a lower speed is required, but what about torque?
Are the two glass diodes serving to rectify the other AC half, making the SCR behave as a DC speed controller on a universal motor? Perhaps, the circuit is serving the same function as the DIAC circuit by triggering phase angles?
New Switch Revealing Circuit Board
Front of New Circuit Board
Poor attempt at creating a schematic
