I am using a resistor divider to an analog pin on Arduino to sense the voltage of a battery. I've recently been going through my IC's and found a device that can be used as a voltage buffer. I am aware that a voltage buffer spits out what it gets in, so 5V in is 5V out. However, I am unclear on:
A voltage buffer amplifier is used to transfer a voltage from a first circuit, having a high output impedance level, to a second circuit with a low input impedance level.
Further, will this benefit my resistor divider given that their might be fluctuations in load on the circuit due to devices drawing more or less power causing inaccurate measurements?
Please explain as if I am a layman, I'm just starting to get into more advanced electronics aside from connecting pins together.
