14
The best way to protect AVR pin for me is RC filter and TVS diode but I don't know one thing. I've seen schematics where TVS diode was before RC filter like in first schematics.
But before resistor it is larger current so TVS diode will blow faster than in situation that TVS diode would be behind RC like in second schematics.
Question is: Which way of protecting AVR input is better, first or second?
  • \$\begingroup\$ What says in the AVR datahseet about the voltage and current limits? No ESD protection for the input ? \$\endgroup\$
    – R Djorane
    Commented Dec 7, 2016 at 14:28
5 Answers 5
17
You have three components there that are all there for protecting the AVR, but all are doing a different job.
The resistor is there to stop steady state high voltages.
The capacitor is to remove ripple/RF/slow transients.
The TVS is to suppress fast transients.
In order to get the best out of your protection, you need to have the shortest (lowest inductance) path back for the fast transient impulses (such as ESD). To do this, you fit the TVS (the fastest responding device) as close to the input to the board as possible. The capacitor would then be a bit further in (depending on the layout and design) and the resistor (which only deals with very slow, or steady state situations) can pretty much be on the pin of the AVR
EDIT: As some of the other answeres have added, you can use diodes (mainly Zener diodes) to clamp the voltage of the signal rail. The important difference between Zener diodes and TVS diodes is the speed of reaction and power dissipation: a Zener will clamp the voltage at steady states, but will not catch the quick spikes from ESD or similar events. A TVS will react quickly and catch the spike, but is not designed to handle a continued over voltage event.
    \$\begingroup\$ I keep hearing that TVS and Zener handle different faults, so you need both, but I can't find an example of how to actually use them together. \$\endgroup\$ Commented Jun 12, 2021 at 23:50
10
Resistors are useful before and after the TVS to serve different purposes. The cap may be placed either in parallel with the TVS or directly at the processor pin; the latter will provide somewhat more protection, but will also cause the processor to respond more slowly to changes in the input.
If the input to the device were connected to a charged-up capacitor (e.g. 100V) and there were no resistor anyplace, the TVS might quickly clamp to 6V, but the processor's internal protection diode would have a very large amount of current forced through it with a one-volt drop. The vast majority of the energy from the capacitor would be dissipated in the TVS, but the processor would still absorb a damaging amount. Further, almost all of the energy would need to be handled by the TVS.
Adding a resistor between the outside world and the TVS would reduce the current, but since the resistor would have almost 100 volts across it, it would pass a significant amount of current, and that current would end up flowing through the chip's protection diode. As above, the TVS would help, but leave a large amount of energy for the chip to handle. In this scenario most of the energy would be dissipated by the resistor rather than the TVS, so the TVS would be stressed less severely.
Placing a resistor between the TVS and the chip, but not between the TVS and the outside world, would protect the chip provided the TVS was able to clamp the voltage effectively, because the resistor itself would only have a few volts across it. The TVS, however, would be taked with dissipating almost all of the energy from the capacitor.
Placing a resistor on both sides of the TVS would provide by far the best protection. Most of the energy would be dissipated in the first resistor, making it much easier for the TVS to absorb the rest, while the second resistor would limit the peak current fed into the CPU.
The circuit above can be simulated, with the relays opened and closed to show different combinations of resistors being present and absent. Use the "Simulation" button and "Time domain" tab, and "run time domain simulation". The top trace shows the current in the suppression diode and the "chip" [simulated at the right by a diode and resistor to VDD]. The bottom trace shows the current through the right-hand protection resistor; that will be zero when the relay is shorting out the resistor, but it shows the current in milliamps rather than amps. Adding the first resistor greatly cuts the total amount of current absorbed by the suppression diode and chip, but with just the first resistor the chip still has a rather high peak current. Adding just the second resistor would protect the chip pretty well, but leave the suppression diode absorbing a lot of current.
  • \$\begingroup\$ Thank you for reliable response! I decided to give 2 resistors, one before TVS and one behind \$\endgroup\$
    – Piotr
    Commented Dec 7, 2016 at 16:52
If you power your device with 5V supply, you need to make sure that pin input voltage stays in certain range (deprend on the datasheet), When input voltage source is taken from same power supply, then you don’t have to worry much about it.
But what if AVR is accepting digital signals from other sources like sensors, other devices that are powered with their own power supplies. Can we be sure that voltage will always be within safe limits ? This is whay you need to use two ESD diodes (D1 and D2) instead of one TVS to protect logic from over-voltages and under-voltage. And if you expect that input voltage may be off limits we need to add current limiting resistor R1 and a capacitor C1 to make a RC filter, Resistor part serves as current limiting resistor while capacitor adds filtering of glitches and debounces input signals. enter image description here.
I hope this answers your question.
  • \$\begingroup\$ You can also use a bidirectional TVS. \$\endgroup\$ Commented Dec 7, 2016 at 14:41
  • \$\begingroup\$ Here there are Zener diodes to clamp the voltage. TVS diodes are used to react quickly to high spikes, but aren't designed for continued over voltage events. \$\endgroup\$
    – Puffafish
    Commented Dec 7, 2016 at 14:42
    \$\begingroup\$ @Puffafish whene i said ESD diode it can be TVS or zener diode, but usually is TVS diode which offer the most optimized balance between low clamping voltage and low capacitance. \$\endgroup\$
    – R Djorane
    Commented Dec 7, 2016 at 14:52
  • \$\begingroup\$ I have for example switch connected to ground from one side and from other signal line pulled up to 5V by internal AVR resistor. There are transients from turning on/off switch. How can I make it 'indestructible'? Resistor in series to limit current (for AVR's 20mA), capacitor to slow transients and TVS diode with breaking voltage > 5.1V to protect from positive spikes will help? AVR's have also internal diodes but for only 1mA forward current. \$\endgroup\$
    – Piotr
    Commented Dec 7, 2016 at 15:12
  • \$\begingroup\$ Yes i think it will help, usually i use a TVS diode with nominal breaking voltage 5V6 for an input with 1,2V to 5,5V. For you if your input can handle 5V max a TVS diode with 5V1 nominal breaking voltage is sufficient. \$\endgroup\$
    – R Djorane
    Commented Dec 7, 2016 at 15:24
If you put the resistor "outside" (towards the source of the transient energy) of the TVS, it will dissipate some of the transient energy when the TVS turns on. This will allow you to use a smaller (lower energy rating) TVS.
Look at it this way:
  1. The transient occurs, and there is no current flow, but a high voltage appears on both sides of the resistor.
  2. The TVS sees this high voltage and conducts to ground.
  3. That's effectively a short circuit, so now current begins to flow through the resistor and the TVS to ground.
  4. The IR losses in the resistor dissipate the transient as heat
  5. The maximum current seen by the TVS is limited to V(transient)/R
    \$\begingroup\$ If you put the resistor "outside" and are relying on it to dissipate some of the transient, make sure you use a large enough package to prevent flashover. \$\endgroup\$ Commented Jun 12, 2021 at 23:52
  • \$\begingroup\$ I'm worried about the voltage drop across the resistor. Usually for a 0603 package, the maximum dielectric withstanding voltage is 150V (300V for 0805). The resistor can be damaged by the high voltage. \$\endgroup\$
    – Motla
    Commented Apr 19 at 8:17
The second one.
With this layout you are protecting the microcontroller from damage, and also protecting the input signal from shorting to ground via the TVS when it is clamping a transient.
Edit:
@Puffafish is right. You will get the best protection putting the TVS at the signal input. So the first layout is better.
Anyway, putting a resistor before the TVS has the benefit of protecting the input singal (and the TVS itself).
