I need to run a 2 meter data cable from an Arduino UNO to a series of 40 RGB LEDs with integrated WS2811 drivers. What kind of cable do I need? Do I need something between the cable and the first rgb LED to "clean up" or enhance the signal?
The 2m cable goes to the first LED only. Between each LED there will be 10~20cm of cable. What cable should I use for that connection?
So absolutely worst case (40 LEDs, all 20cm away from each other), that's 8 meters of cable in total (in practice I think 6-7 meters will be the maximum). Is this doable or will the LEDs misbehave? I know that these LEDs are very timing sensitive because they are sending data to all the LEDs on one line.
