If I wanted to re-route SBU1 and SBU2 to a separate controller because I only intend to use the USB 2.0 capabilities of the wire - Do I have to worry about the EMCA chip interfering?
Does the USB MUX happen in a EMCA cable - or does it happen host/device side?
You have a few mix-ups here.
  1. Electronic Marker is connected to CC1/CC2 wires, so they can't interfere with auxiliary wires;
  2. There is no SBU wires in a Type-C USB 2.0 cable. You will need to use a full-blown USB 3.1 Type-C cable assembly for this.
  3. No USB cable does any MUX. Ever.
  4. I wouldn't worry about eMarked cables at all. They are reaaly difficult to come by.
  • \$\begingroup\$ Thank you! (1) This is what I kept seeing in the diagrams - I just wanted to be absolutely sure. (2) I should have clarified. I am only interested in using the 2.0 capabilities of a Type-C wire at the moment, I do not intend to use a USB 2.0 cable as it is only required to use 4 wires. (3) That is good news. I kept finding chips in type-c cables and I couldn't tell if they were only ID chips OR if they did more. Makes sense that the MUX is on the other side of the port. \$\endgroup\$
    – wookie4747
    Commented Jan 27, 2017 at 3:10
