I have an IR Controlled Relay module (Schematic below). I have programmed it to work with an old Comcast remote (Silver with red select button). The problem I am having is the remote send the power signal multiple times per button press instead of just once. This causes the relay to switch rapidly and often end up in the same state as before you pressed the button.
So what I need to do is modify the circuit so that only the first signal gets through and the rest are ignored. I would assume that using a capacitor to smooth out the signal would be required, but what capacitance, where exactly should it go, and ceramic or electrolytic?
NOTE: This schematic was provided by the manufacturer in Chinese. I translated it but there is one existing capacitor (C1) that is a surface mount and I see no way to identify it.
What about using a 555 and this logic?
