A question came up about common failure mode of a transistor. Searching past posts I actually found varying answers, either open or short. Maybe it depends on the application, and I'm missing something?
"The output of a TTL NAND gate is being used to drive a relay ON by pulling the source low. The diode for the relay was installed backwards, effectively shorting the gate's output to the power supply. Which component has most likely failed?
- The gate's output transistor has failed open
- The gate's output transistor has failed shorted"
The book provides that 'open' is the correct answer, not 'short', but doesn't explain why.
