1 GigaOhm resistors are so damn expensive.
(Don't ask, I'm trying to build a large diaphragm condenser microphone from scratch)
As an microphone pre-amplifier I am trying to bias a transistor and charge the capacitor plate at the same time similar to the setup in the Alice microphone circuit:
While I could just use AC coupling in between the capsule and the transistor base, I want to try and minimize middle-man components but also achieve decent amplification with little noise. I was wondering if it was sane to substitute the single 1G resistor with a current divider setup.
P.S: If the answer is no, I will have to resort to using a Popsicle stick instead.
