this is my first post here pardon me if this question is idiotic :)
I made a voltage divider by following the image below
Voltage Divider
But when I connect 12v supply the resistor getting very hot just in 2seconds what am I doing wrong ?
    \$\begingroup\$ What else is attached? Have you verified each of the resistances with an ohmmeter? \$\endgroup\$
    – jonk
    Commented Feb 2, 2017 at 18:25
    \$\begingroup\$ Yes, check your resistors. each of those 12k resistors should be dissipating about 0.003 watts, which should not cause noticeable heating of any resistor you are likely to be using. \$\endgroup\$ Commented Feb 2, 2017 at 18:29
  • 7
    \$\begingroup\$ Are you using 12 ohm and 10 ohm resistors? \$\endgroup\$
    Commented Feb 2, 2017 at 18:33
  • \$\begingroup\$ k = 1000 hobby-hour.com/electronics/resistorcalculator.php \$\endgroup\$ Commented Feb 2, 2017 at 18:58
k means kilo-ohm. For example 10k means 10000 Ohms. Check by ohmmeter if you had not understood the color codes . Alternatively your voltage is higher than you think. I have done the later error by an 10x oscilloscope probe.
  • \$\begingroup\$ Thank you for the answer, Yes it was my mistake i took 10 Ohms resistors instead 10K @andy-aka \$\endgroup\$ Commented Feb 4, 2017 at 8:57
