When having a resistor(R) in series with a diode(D), i keep seeing that in order for the diode to be conducting electricity the voltage on the branch R+D should be higher than the diodes potential. But what happens to the voltage drop on the resistor, why doesn't it get calculated?
  • \$\begingroup\$ I assume with diodes potential you mean forward voltage, don't you? \$\endgroup\$
    – Curd
    Commented Aug 9, 2017 at 22:41
  • \$\begingroup\$ Yes, i think that answers my question. \$\endgroup\$
    – user159536
    Commented Aug 9, 2017 at 22:42
You only have to make sure the voltage across R + D is higher than forward voltage of the diode, because the resistor has to take what is left; unlike the diode a resistor conducts even at voltages close to 0V.
