Datasheet
Application Note
I'm working with the atmel m90e26 IC. Its energy is numerically pulse_based, but I do not know what the relationship between energy and pulse is in this IC. There's a parameter named MC=3200 imp/kWh in the application note I attached it with the datasheet. Maybe this parameter is related to my problem.
What the relationship between energy and pulse is in this IC?
-1
Once you make an energy meter, it won't directly give you the accurate reading of 3200 impulses per kWh. You need to calibrate each energy meter circuits individually against a standard meter.
For your chip (M90E26), it requires writing to some calibration registers. Check section 3 of your document.
If this calibration process looks too complicated to you, you can go for simpler chips where calibration requires shorting of binary ladder resistors on the voltage sampling channel. Example of such an IC - BL0921.
  • \$\begingroup\$ thanks. i did some of the calibration but i know nothing about what MC is and how to calculate it.could you please explain more ?? \$\endgroup\$
    – shima sh
    Commented Aug 20, 2017 at 7:13
-1
Your component will pulse 3,200 times, over the course of a KWh. If it's pulsed 1600 times, that's 0.5KWh.
Conversion from KWh to energy is possible, but if you're building an energy meter you don't want to record energy. You want Power over time, measured in KWh... Because that's what they bill you for.
Rational: I have built an almost identical project.
  • \$\begingroup\$ No, you are billed for energy you use, and kWh is energy. You do not want power over time, and kWh is power times time. \$\endgroup\$ Commented Apr 24, 2020 at 11:58
  • \$\begingroup\$ I'm billed for KWh. More to point, 1 energy is measured in Jules, not Watts. W=1J per second. 1Wh is 1J every second for an hour, or 3600J. While you can move between energy and work done over time, why bother? Your actual bill is in KWh, aka "units". \$\endgroup\$ Commented Apr 24, 2020 at 12:39
  • \$\begingroup\$ Of course you are billed in kWh because it is energy and you are billed for the amount of energy you consume. Energy is not measured in "Jules". The SI unit for energy is the joule. The SI unit symbol for the prefix kilo is k. The letter K is the SI unit symbol for thermodynamic temperature. \$\endgroup\$ Commented Apr 24, 2020 at 14:29
  • \$\begingroup\$ That's what you get for commenting on a phone with autocorrect. \$\endgroup\$ Commented Apr 24, 2020 at 15:45
  • \$\begingroup\$ I don't understand your point. Are you acknowledging the mistake and blaming it on your phone? \$\endgroup\$ Commented Apr 24, 2020 at 17:18
