I'm trying to implement read and write routines using Polling method for a PIC18LF24K40, write seems to work, but not read. I cannot figure out what i am doing wrong.
EDIT: Reading a byte stored in a register on a slave chip:
   void read_LDC_reg(U8 *dest_addr)
      U8 temp=0;
      if( ( check_for_bus_free_iic() == 1) )
      send_start();
      PIR3bits.SSP1IF=0;
      I2C_wait();
      send_address(U8_LDC_I2C_ADDRESS,READ_BIT);
      send_start();
      SSP1CON2bits.RCEN1=1;
      while(SSP1STATbits.BF==0);
      temp=read_from_slave();
      PIR3bits.SSPIF = 0;
      dest_addr =  &temp;
      send_stop();
send_start() looks like this:
void send_start()
    while(SSP1STATbits.RW);          // wait for write to complete
    SSP1CON2bits.SEN=1;              //set start enable bit
    if(PIR3bits.BCLIF==1)
        PIR3bits.BCLIF =0;  //Clear collision bit in PIR register
    while(SSP1CON2bits.SEN);         //waits to get cleared by hardware
I2C_wait looks like this:
void I2C_wait(void)
    while( (SSP1STAT & 0x04) | (SSP1CON2 & 0x1F) );
    PIR3bits.BCL1IF=0;
send_address() looks like this:
void send_address(unsigned char addr,unsigned char ReadWrite_bit)
    unsigned char temp=0;
    temp = ( (addr <<1u ) | (ReadWrite_bit & (unsigned char)0x01) );
    write_to_bus(temp);
write_to_bus() looks like this:
void write_to_bus(unsigned char data)
    send_start();
    I2C_wait();
    send_byte(data);
    I2C_wait();
    send_stop();
read_from_slave() looks like this:
unsigned char read_from_slave(void)
    unsigned char rcvd_byte=0;
    rcvd_byte = SSP1BUF;
    return rcvd_byte;
I am getting unexpected values from the slave register, i do not know why i believe i have initialised correctly, i can see the SCL and SDA waveforms on Oscilloscope.
EDIT: Hardware is fine, I2C works perfectly when i use the I2C Driver code generated from MCC(MPLAB Code Generator), i want to reduce the overhead caused by MCC in my project, thats the reason im going for I2C using Polling option.
  • \$\begingroup\$ How do you know the writes are working if you can't read? Do you have access to registers on the other device? \$\endgroup\$
    – user4574
    Commented Jan 8, 2021 at 17:10
Your problem may have very little to do with I2C and much more to do with your use of the stack and pointers.
I see some issues with the following code.
      U8 temp=0;
      dest_addr =  &temp;
It looks like you are attempting to store a byte into temp and then return the address of temp from the function. There are two problems with this.
  • Temp is stored on the stack. So when you return it no longer exists. The compiler can re-use that stack space for other stuff, which would over-write your value.
  • You are not actually returning the address of temp properly. dest_addr is a pointer to an 8 bit integer. It lives on the stack. When you return from the function it no longer exists.
What you should be doing is...
  • Allocating temp somewhere outside of the read_LDC_reg function.
  • Passing the address of temp into the function.
  • Dereferencing the pointer address to store the value into temp.
The code is shown below.
void main(){
    U8 temp=0;
    read_LDC_reg(&temp);
    //At this point temp contains the byte read from I2C
void read_LDC_reg(U8 *temp){
      *temp=read_from_slave();
      send_stop();
Load test values in a dummy MCU and try simulating with the Proteus design suite, but i agree with Buhra with checking the flag for successful reception from the slave, and if possible check necessary flags that indicate a free buffer and transmission-ready state.
   <----------- Check Flag ------------>
    return rcvd_byte;
In this function you are not check any flag for successfull reception from slave,Check datasheet again
  • \$\begingroup\$ I have not enabled ACKEN bit so I'm not sure if i need to check if ACKDT bit is set on Receive. Probably i have to set ACKEN \$\endgroup\$
    – Abel Tom
    Commented Oct 24, 2017 at 6:03
  • \$\begingroup\$ what do you mean by I have not enabled ACKEN bit . Check previous reception is complete or not using flag,there is no matter of ACK. \$\endgroup\$
    – Bhura
    Commented Oct 24, 2017 at 6:41
  • \$\begingroup\$ I modified the read from register routine, i check if the buffer is now full, but i receive 0xFF for some reason, always. \$\endgroup\$
    – Abel Tom
    Commented Oct 24, 2017 at 6:50
  • \$\begingroup\$ ReCheck your connections, I2C Master SDA -> Slave SDA and SCK -> SCK with pull ups 1K'oms -> 4.7k'oms and what freq you are using for I2C communication can you provied whole code. \$\endgroup\$
    – Bhura
    Commented Oct 24, 2017 at 7:08
  • \$\begingroup\$ Pullups are around 2.2K, Clock frequency is set to 100KHz. Hardware is fine, I2C works perfectly when i use the I2C Driver code generated from MCC(MPLAB Code Generator), i want to reduce the overhead in my project, thats the reason im going for I2C using Polling option. \$\endgroup\$
    – Abel Tom
    Commented Oct 24, 2017 at 7:11
