I am using Comparator (schematic shown below). I have connected output with Vcc via 2k ohm resistor, as it has open collector output.
In this configuration output of the opamp should be 3.3V. But the output is coming 0V.
But if I change the supply voltage to 5V, then the output is showing 5V. (schematic below)
Is there any rule "voltage at the terminal (inverting/non-inverting) of the comparator should not be higher than supply voltage of the opamp.
Regards,
