charge a capacitor from say a 3V battery you get Q charge in T seconds. If you double the voltage to 6V you get 2Q charge also in T seconds
Actually, probably you don't. Depends on 'R'.
$$Q = C \times V_{capacitor} $$ $$
V_{capacitor} = V_{battery} \times (1- e ^ {-T \over{R \times C}})$$
If your '3V' source is a battery, with some internal series resistance,
and puts Q charge on an uncharged capacitor in a short time T, then a '6V' source might
be two batteries in series, with twice the internal resistance,
and will put 2Q charge on a capacitor in time 2T, through resistance 2R.
In very long time scales (times much greater than the product
of resistance and capacitance), the capacitor and battery circuit
can be deemed to have negligible resistance (because the current
times resistance is very small when the capacitor is near fully charged),
but that is an approximation that does NOT allow a prediction of
time versus voltage, only allows the prediction of the at-equilibrium
charge.
In a time model, you NEED to be explicit that there is a resistor,
but if none is 'designed' in, the resistance comes from
stray effects. Batteries' internal resistance when placed in series,
for example.
