I have received a 18V 2.5W photovoltaic panel and want to use it to either charge a cellphone (or even two at the same time) or power some Arduino projects. In both cases I need a 5V source, but mine is said 18V.
If I understand charging a device well, it is important that the source's voltage doesn't exceed the device charging recommendations, which are usually 5V, but the opposite is no problem.
How can I best make sure I get 5 Volts ?
Under the ideas I have in order to achieve that there are :
  • Using a diode in order to subtract a constant amount of voltage util there are only 5V left, but it seems to me that's a very bad idea since if a cloud covers the sun, I would get less than the initial 5V, which is not dangerous, but unfortunate.
  • Using some resistors (able to withstand 2.5W), but that would mean that I also need to know the resistance of my cellphone/Arduino project etc. in order to make a voltage divider... And on holiday I'm not very likely to have a multimeter in range... And it may be unfortunate to dissipate so much energy though a resistance.
  • Using a charger bought on the market, but I assume they won't do the job since they are usually designed to be used in a range from 110V to 220V. (Secondary question : how do chargers actually convert voltage ?)
  • Look for another solar panel :)
Thank you very much in advance for your answers.
  • \$\begingroup\$ A DC/DC converter with suitable input range and 5 V output. Take a look on eBay or similar. \$\endgroup\$
    – winny
    Commented Feb 8, 2018 at 17:10
  • \$\begingroup\$ Similar: electronics.stackexchange.com/questions/137640/… \$\endgroup\$
    – winny
    Commented Feb 8, 2018 at 17:13
  • \$\begingroup\$ A nominal 2.5W panel is not going to do much charging unless it is an old phone with a small battery. Basically, it is a waste of time. You may be able to power the arduino, though, if it only needs, say, 1W or 1.5W max. Look for a buck DC-DC converter that can handle 20V in and produces 5V out. \$\endgroup\$
    – user57037
    Commented Feb 8, 2018 at 17:21
  • \$\begingroup\$ Should I better try to exchange it against two 5V 250mA panels which I could then connect in parallel to obtain the 0.5A rated to charge a cellphone ? \$\endgroup\$ Commented Feb 8, 2018 at 17:29
Solutions 1 and 2 are going to waste most of the power from the solar panel as heat. What you're looking for is called a buck converter and you should easily be able to find one that steps down 10-25V to 5v.
Something like this would work, it has 4-40V input and adjustable output.
You can get these converters in prepackaged form : they are 12-24V to 5V converter for cars/trucks.
Note that the 18V 2.5W will only geterate 2.5W when in full sunlight and at proper angle, which means it will generate a lot less under realistic conditions.
Most phones require at least 5V 500mA which is 2.5W for slow charge, or 5V at 1-2A (5-10W) for fast charge. So the panel will not generate enough power.
