I have an AC Servo from Harmonic Drive (type RSS-20-6006S) that I have no information on.
I am used to encoders with several leads, including differential A B and Z wires, but I have never seen 14! They each have a unique color in a rainbow spectrum.
I can't seem to find much documentation about such 14 wire encoders, but I saw them mentioned as "a standard" somewhere in Harmonic Drives website, but can't seem to find any specification. Any suggestions on how to troubleshoot this encoder? Is this an industry or Harmonic Drive standard that maybe was "phased out"?
    \$\begingroup\$ contact the manufacturer \$\endgroup\$
    – jsotola
    Commented Feb 25, 2018 at 5:16
  • \$\begingroup\$ I'd guess it is literally: supply, common, and 12 bits. \$\endgroup\$
    – Jeroen3
    Commented Feb 25, 2018 at 13:23
    \$\begingroup\$ Probably a Gray encoder; the Wikipedia article even has a picture of an absolute encoder with 13 bits, so close to what you have. \$\endgroup\$
    – JvO
    Commented Feb 25, 2018 at 16:05
Assuming that you are, in fact, looking at an encoder, it is an "absolute" encoder. Instead of ABZ, it finds all 12 bits of position in the encoder, then puts them out single-ended. Plus a V+ and ground. This isn't used much nowadays, since an ABZ interface is simpler and the computation needed to back out position is cheap, but it used to be fairly common, particularly in encoders with relatively high resolution. It has the obvious advantage that you get position on power-up, with no need for a home cycle. It has the disadvantage that the unit is more expensive : the encoder disk is more expensive, since it requires 12 tracks (one for each bit) rather than 3, plus it needs 12 optical sensors.
As for your specific unit, it is almost certainly no longer supported. I'd suggest actually phoning Harmonic Drive and throwing yourself on the mercy of a support person. Often, (especially if you find someone helpful) they'll go do some digging. Or not, depending on how overworked they are.
