I'm working with an electric resistor (oven resistor) and I want to compute the active power with an embedded system.
My idea is to use a current probe around the phase wire to acquire the current values. I would avoid to acquire the voltage values because this implies the addition of a circuit to sample the voltage.
With the oscilloscope I can compute the active power: V(t) * I(t).
Is it possible to compute the active power only sampling the current? Is it possible to use a sampled voltage period to perform the computation?
Thanks for the help!
