I would like to estimate the current consumption of the FT2232H chip and I have some unclear issues with it.
In the chip's datasheet, it says the current for each voltage rail(except VCCIO).
In Digikey and a reference design that I have found it says that the chip current supply is 70mA at a supply of 3 - 3.6V - I think it might be a mistake. because the datasheet says the same current supply for the VCORE voltage rail (Icc1)
Also, the datasheet doesn't mention VCCIO's current supply. Is it possible to calculate the current consumption without this parameter?
I would like to calculate it by myself. How can I do it?
Thank you very much!
