I found this component connected in parallel with an inductive load ( three phase coil used to disengage a mechanism ) the load keeps heating and burning after a while ( had to rewind it ) and no fuses burn or circuit breaker trip ,can this component be the reason? how can I test it?
The data sheet ( if it's the right one ) says it's an RC circuit with 0.22uf+220ohm. R101 datasheet The supply voltage is 380v three phases , the load and this component are connected in parallel. The load is 3 sets of two in series coils , where the sets are connected in star connection.
