This 12V DC breaker panel is meant to carry up to 100A, but provides a fairly small stud for terminal connection. The product documentation doesn't appear to indicate the stud size; it was measured with a caliper at 3/16" (#10). The product manual itself recommends use of 2 AWG wire, for which ring terminals/lugs smaller than 1/4" do not appear to be manufactured.
Is it generally safe to use a 1/4" ring terminal on a 3/16" stud? Are there any special considerations? If I were to add a flat washer to stabilize the connection, how would I know what material it should be made from?
