I'm trying to learn about different applications of RLC circuits and have been presented with a weird looking circuit...
I've only ever dealt with circuits that can be modeled with a 2nd-order differential equation, so I'm unsure how to approach this. I've researched the circuit and found this article on low pass filters comprised of LC components. This is a lot different than the RC low pass filters I've studied.
Is the circuit above a low pass filter as well? Does the resistor merely a load resistance or does it influence the behavior of the following LC components? The values aren't provided in the graphic, but C1 and C2 have different capacitance values. The article shows the capacitors both being equal to C/2.
How would I relate the output voltage y(t) to the input voltage x(t) using a differential equation? I tried to create a differential equation using mesh analysis but quickly got mixed and couldn't figure out how to manipulate the equations I got into a differential equation. This article shows a similar circuit being solved but I'm confused by how everything relates.
Here's what I've done thus far...
EDIT: I think I figured it out...
