The input signal to my board is an AC signal.
My board will process this signal. My board can handle 3.1Vpk-pk maximum without any damage occurring.
In the event that my input signal exceeds that I want to build a circuit that can stop (and hold or hold it at 0V if easier) the input to the board at 3.1Vpk-pk.
What I want to do: for signals in the range 0-3.1Vpk-pk they will pass through the circuit unaffected, for signals above this the output can be either a constant value or zero, which ever is easier to design. We can assume that the maximum voltage that could be supplied can go up to 20-30V while the typical input will be in the range 0-3.1Vpk-pk. The signal's frequency should be unaffected by this circuit.
I have been searching for days for protection circuits but cannot find any for an AC input signal which is unbelievable to me.
How to I go about designing and building this? My initial simulations included a unity gain buffer that would saturate at max input but this failed.
Any guidance to the name of this circuit or guidelines that can help me design one on my own will be great. Thank you.
