I am building the Velleman K1803 pre-amplifier kit. This amplifier has a maximum input signal of 40mv. The audio input to the pre-amplifier will be a piezo-electric sensor, and this can certainly exceed the specified maximum.
I believe that the input can be protected with a pair of diodes, but there is a huge range of diodes available.
It is some time since I have done any electronics, and so far my searches have not resulted in a suitable circuit design which could achieve the protection at the low signal voltage specified. For the record, the input is audio in the range 20Hz to 20kHz, and could possibly lie in the range +/- 0.5V.
I would appreciate some guidance on where to look for a suitable diode and circuit. I can of course supply a circuit diagram of the amplifier if needed
Added:
Following @DrMoishePippik comments on back-to-back schottky diodes, the lowest switch-on voltage I have found is 0.33 to 0.45 for the BAT43 small signal Schottky diode.
    \$\begingroup\$ Normally you would clamp to the maximum that the input can take, not the expected maximum of the signal source. It is likely that the 40mV maximum is the maximum that the amp can take and still work properly...but you're not worried about that. You're worried about the maximum it can take and not have damage occur. There's a difference. You can either use a TVS diode that clamp in reverse-breakdown or "regular" sufficiently fast diodes that clamp in forward bias to clamp the voltage to the rail supply (but this requires a rail supply to be present). \$\endgroup\$
    – DKNguyen
    Commented Mar 27, 2019 at 22:55
    \$\begingroup\$ The maximum input is specified as 40mV because the gain is up to 100 and the minimum Vcc is specified as 10V, giving you 5V peak output, or 3.5VRMS, so 40mVRMS roughly defines a clipping point rather than the damage point. A much larger input won't damage the first op-amp, up to at least the voltage rail. \$\endgroup\$
    – user207421
    Commented Mar 28, 2019 at 2:40
  • \$\begingroup\$ Thank you for clarifying the reason for the low maximum input. If I have read the data sheet for the LM358 correctly, it confirms that the maximum input signal voltage range is -0.3 to +32 volt. \$\endgroup\$
    – Geoff
    Commented Mar 29, 2019 at 13:21
  • \$\begingroup\$ Search BAV 23s diodes.... \$\endgroup\$ Commented Sep 10, 2021 at 16:52
Just change one of the feedback resistors to have less gain so it can accept larger input voltages without clipping.
A pair of inexpensive back-to-back silicon diodes across the input lines should be sufficient to limit input to 600 mV. Germanium diodes or Schottky diodes would keep the voltage lower yet, but they're generally more fragile and/or more expensive than ordinary Si iodes. Since the specifications limit response to 20 kHz, even Si rectifier diodes should not degrade performance noticeably.
Though the maximum rated signal for the Velleman K1803 is 40 mV, there is no DC path from input to IC1a, below, so a transient 600 mV should do no harm.
Velleman K1803 schematic from https://www.velleman.eu/downloads/0/illustrated/illustrated_assembly_manual_k1803_rev2.pdf
    \$\begingroup\$ R2 puts a severe limit on transient current into the IC anyways. Not sure the OP has a transient problem to fix. Reducing R5 to reduce gain may be a better choice. \$\endgroup\$
    – user105652
    Commented Mar 28, 2019 at 1:07
  • \$\begingroup\$ reducing R5 may cause oscillation; that OA is already at unity gain. \$\endgroup\$ Commented Mar 28, 2019 at 3:35
  • \$\begingroup\$ At max (100X) gain, this "preamp" will have 40nanoVolts/rtHz * sqrt(20,000Hz) * sqrt(2 res of 100K) * pi/2 * Av = 220/2.2 == 15uVrms * 100 = 1.5 milliVolts rms random noise, provided by R2 and R5. \$\endgroup\$ Commented Mar 28, 2019 at 3:39
