I have some random issue with data saved in flash on PIC32MX470F512L.
Since there is no EEPROM, part of the flash storage is used to save configuration and some statistics (ie.: reboots reason, errors on serial communication, etc).
Over about 50+ units, randomly part of configuration change, the cause is not found but some hypothesis for the moment :
- No capacitor on MCLR
- Reading of the configuration in flash before VDD fully stabilized
- Power off during flash write
I am sure there is not enought writes to go beyond limit, somewhere between 1 and 25 writes per day.
Yet I've not been able to reproduce the issue periodically.
Here are some relevant parts of the code...
Main
int main()
/* Variables defines */
//Configure l'horloge systeme
SYSTEMConfig(GetSystemClock(),SYS_CFG_WAIT_STATES | SYS_CFG_PCACHE);
//Active le watchdog (periode de timeout de 8sec)
EnableWDT();
//Initialisation de la configuration non volatile
config_init();
/* Other init stuff */
//Gestion des statistiques de demarrage.
if(mGetWDTOFlag())
{ //Reset par watchdog
mClearWDTOFlag();
g_stConfiguration.stats[STAT_REBOOT_WATCHDOG]++;
config_saveStats();
else if(mGetPORFlag())
{ //Reset par switch
mClearPORFlag();
g_stConfiguration.stats[STAT_REBOOT_NO_POWER]++;
config_saveStats();
else if(mGetBORFlag())
{ //Reset par mauvaise alimentation
mClearBORFlag();
config_saveStats();
else if(mGetMCLRFlag())
{ //Reset par mclr (bouton reset)
mClearMCLRFlag();
g_stConfiguration.stats[STAT_REBOOT_OTHER]++;
config_saveStats();
else if(mGetSWRFlag())
{ //Reset software (non implemente encore)
mClearSWRFlag();
config_saveStats();
/* Going to main loop */
Flash utility functions
void config_init() {
// Lecture de la configuration presente en memoire
nvm_lireConfig(&g_stConfiguration,NVM_PAGE_CONFIG);
* Si le numero d'ordinateur est zero c'est parce qu'il n'y a rien dans la
* flash, on va charger les valeurs par defaut.
if(g_stConfiguration.numero_ordinateur == 0)
config_defaut(&g_stConfiguration);
nvm_ecrireConfig(&g_stConfiguration,NVM_PAGE_CONFIG);
nvm_ecrireConfig(&g_stConfiguration,NVM_PAGE_CFG_BKP);
void config_saveStats()
void nvm_lireConfig(void *dataAdr, int pageNumber) {
memcpy(dataAdr,(void*)eedata_addr[pageNumber],sizeof(ComputerConfiguration));
int nvm_ecrireConfig(void * dataAdr, int pageNumber) {
int pagebuff[1024]; //Buffer d'une page, necessaire pour la fonction NVProgram
// On efface la page avant d'ecrire dedans
if(nvm_effacer(pageNumber) == NVM_SUCCESS) {
// Ecriture des donnees dans la NVM
if(NVMProgram((void*)eedata_addr[pageNumber],dataAdr,sizeof(ComputerConfiguration),(void*)pagebuff) == 0) {
// Verification des donnees ecrits
if(nvm_verifier(dataAdr,pageNumber) == NVM_SUCCESS) {
return NVM_SUCCESS;
} else {
return NVM_VERIFY_ERROR;
} else {
return NVM_WRITE_ERROR;
} else {
return NVM_ERASE_ERROR;
int nvm_effacer(int pageNumber) {
if(pageNumber < NVM_NUM_PAGES) {
if(NVMErasePage((void*) eedata_addr[pageNumber]) == 0) {
return NVM_SUCCESS;
} else {
} else {
return NVM_PAGE_OUT_OF_RANGE;
NVMProgram()
erases the page automatically. So what is the purpose ofnvm_effacer()
? Can you show us the source code of it? \$\endgroup\$
