For a miniature product, I want the smallest possible product enclosure around the PCB. I figure I can get away with a 1mm thick metal sheet enclosure.
But I (probably) also need an insulator between the circuit board and the case, so nothing shorts out. What's the thinnest way I can make the inside of the metal case insulative? Paint? Powder coat? Paper?
    \$\begingroup\$ What peak voltage (and max freq)? Any regulatory requirements? In what environment will it operate? \$\endgroup\$
    – tyblu
    Commented Sep 22, 2012 at 4:58
  • \$\begingroup\$ 5v USB used only occasionally. 3.3v logic. +/- 9v peak-to-peak low-current AC. --- FCC. --- Consumer electronics in everyday conditions; continental US. \$\endgroup\$ Commented Sep 22, 2012 at 5:24
8
(1 mm steel is thick!)
The isolation may not be required, since you're probably (S)ELV. Anyway, it's not going to cost you much space-wise. I wouldn't mess with paint sprays and such. Agreed, it's the thinnest, but I assume you can afford the thickness of a 0.1 mm PP (PolyPropylene, PP has very low water absorption) sheet?
Try to use only SMT parts, and mount them single-sided. PTH components will add at least 2 mm because of the pins sticking out at the other side. A single-sided PCB may be glued directly onto the PP sheet, which in turn you glue to the bottom of the enclosure. If you manage to do the wiring of the PCB single-sided as well you don't even need the PP insulation. It may be worth using a couple of 0 Ω jumpers to ease the layout.
You can save an extra couple tenths of mm by using a 0.8 mm PCB instead of the standard 1.6 mm. The thinner PCB is less stiff, but at the small size it's not a problem, and when glued against the enclosure it won't get any mechanical strain anyway.
  • \$\begingroup\$ Thanks! So even if a +5v and a GND are touching the polypropylene 1 mm or 2 apart from each other, it always presents high resistance? \$\endgroup\$ Commented Sep 22, 2012 at 8:29
  • \$\begingroup\$ Is this the stuff? goodfellow.com/catalogue/… \$\endgroup\$ Commented Sep 22, 2012 at 8:30
    \$\begingroup\$ @Evolved - Yep, that's the one. It mentions a roll width of 650 mm, though, and a roll may be 600 m worth (mine is), so that may be, er, somewhat much. You may ask them for a sample. The PP has a volumetric resistivity of > 10\$^{15}\$, which is, er, pretty high. At these low voltages you're absolutely safe. \$\endgroup\$
    – stevenvh
    Commented Sep 22, 2012 at 8:47
  • \$\begingroup\$ For playing (and better) "Mylar" [tm][literally] will do what you want as long as you do not mechanically puncture it. OHP (remember them) projection film is/was usually Mylar. That's a version of Polyester but is going to behave well enough for what you want. \$\endgroup\$
    – Russell McMahon
    Commented Sep 22, 2012 at 11:06
  • \$\begingroup\$ @Russell - I guess a lot of plastics will be suitable, but I'm not a mechanical engineer, nor a chemical one, so I don't know them all. I do know that PP has about the lowest water absorption, and a high resistivity (I forgot the dimension ohm.cm in my previous comment). \$\endgroup\$
    – stevenvh
    Commented Sep 22, 2012 at 11:35
Kapton tape as it's usually called, or generics found under "Polyimide Film Tape" is generally used for this sort of stuff - it's a good and thin insulator, but slightly expensive:
https://www.flickr.com/photos/paintyourdragon/8298241344
you could also just use normal (i.e. vinyl) electrical tape, which is a bit thinker, but also has the benefit of being "softer" and thus less prone to punctures/etc. which may result from a component leg or something sticking out, especially if it was "flush cut" which could result in a sharp edge
https://commons.wikimedia.org/wiki/File:Rolls_of_adhesive_tape.jpg
Single sided PCB, Plastic, Sheet rubber, Bubble wrap, Duct Tape, Wood veneer, a few drops of silicon.
    \$\begingroup\$ The melting temperature of silicon is in excess of 1400 °C. I suspect applying it will cause irreparable damage. It is also known to be a semiconductor rather than an insulator. \$\endgroup\$ Commented Jul 1, 2016 at 19:36
    \$\begingroup\$ Another case of silicon/silicone confusion :) Contrary to popular belief, silicone valley is in California, but not the SF Bay area... \$\endgroup\$
    – AndyW
    Commented Jul 2, 2016 at 18:28
