I need to chose a reed relay for connecting a point to high voltage (probably between 7000V:15000V) or to GND signals. System will have 8 channels (pins). Some of 8 pins will be connected to high voltage signal throught a relay. The rest ones will be connected to GND signal throught its related relay.
As you know relays could be Single or double.
I was searching in digikey, mouser, farnell, etc.. providers and I can only find high voltage single relays (SPST). However, it seems not to be other kind of relays (ie: DPST) for high voltage available on these sites.
I have two questions:
- Does it mean that DPST or DPDT are not manufactured? Do they exist?
- What is the difference between Isolation and commutation voltage parameters?
