My question is regarding programmable power supplies. If I send a SCPI command to the power supply using USB/RS-232 or some other serial communication, how do i know the time taken by the power supply to reach the programmed voltage or time taken by the power supply to interpret the command.
Is this parameter usually mentioned in the data-sheet of the power supply? I am planning on renting a power supply which can turn off and turn on remotely within 4 msec, so i want to be sure that the power supply which i rent has that feature before i put my money down on it.
The power supplies I'm looking at are:
- Sorensen XG60-28 DC Power Supply, 0-60V, 0-28A,1700W
- Keithley Series 2260B 360W
- Tektronix PWS4305
Update: Found an example of what I'm looking for: RIGOL DP800A Series Programmable Linear DC Power Supply1
I need some similar timing parameter which can process the command in less than 1 mSec
