I'm new to electronics, and I'm messing around with the perennial 555 IC. I've been introduced to the following formula which allows you to determine the frequency of the output when put in an astable mode:
f = 1.44 / (r1 + 2 * r2)C
I noticed how voltage is not part of the equation. However, wouldn't the VCC of the IC affect the frequency (generally speaking)? Internally, the IC creates a voltage divider and uses 1/3 and 2/3 of the VCC as references for the comparators. If VCC is 5 V, and it takes an x amount of time for the external capacitor's charge to build up and for the voltage to rise from 1.667 V to above 3.333 V, would it not take longer if VCC were 9 V? The references would now be 3 V and 6 V. If no components have been swapped (external capacitor, resistors), would it not take longer for the voltage to rise from 3 V to above 6 V? Or does the increase in voltage charge the capacitor faster, and the effects cancel out?
