I am designing a low profile space grade buck regulator. I have the following constraints
- ICs must be space grade
- Low component count
- Small size
The converter specifications are as follows. Input voltage varying from 15-25V, Required outputs at 3.8V or 5.6V. I came across this converter design from an LM136 datasheet. Could someone explain the functioning of this circuit. I can understand that there is the standard buck regulator configuration and a difference amplifier using the npn transistors. The switching functionality eludes me
