The schematic below contains an INA826 used to amplify the resistance of the Pt100 RTD across J1. Gain is set to 10 through the 5.49K ohm resistor.
- Is this ciruit amplifying only the voltage across the RTD or are any other voltages involved?
- Why not connect -IN to GND, and +IN to a junction of a 5V voltage divider consisting of known resistance and the RTD?
- What is the advantage of the present schematic over the one mentioned above?
