I have connected the collector of a NPN BJT (DTC144EE) to the Power_ON pin of my lte module (HL7588).
The pin is internally pulled up by a 100k resistor to 1.8V. The module is powered on by driving the PWR_ON signal low (I send 1.8V from my controller to the base of U$1).
However, I ran a simulation in TINA and am seeing .85V at the collector (when I want device in OFF state) when the minimum of a a high signal should be 1.33V.
On U4s Data sheet:
Any ideas on what is going on here? This is the transistor Sierra recommends for both Power_on and Reset signals so it is confusing.
