16
I have an Xbox One controller where the X button did not work anymore. I disassembled it today, to find the reason for this. It turns out, there is a hole in the motherboard near the X button:
Hole in Motherboard
There was this sticker right above the hole (it seems that "XJY" is an abbreviation of "Shenzhen Xinjiaye Electronics Technology Co., Ltd.", which is a chinese company that builds such motherboards):
Sticker
Now to my question: is it possible that the adhesive of the sticker in combination with the flowing electricity on the motherboard has caused a corrosive reaction, resulting in the hole? I think there is no mechanical cause, since the wires in the hole are still largely intact and the "missing" part of the motherboard was not inside the controller.
  • 4
    \$\begingroup\$ Unlikely. If the corrosion happened after the board left the factory, nobody would have made those "repairs" to try to fix it. \$\endgroup\$
    – The Photon
    Commented Nov 6, 2019 at 21:53
  • 18
    \$\begingroup\$ This is probably a hack the manufacturer used to correct a flaw in the production board that they made a bunch of so they didn't have to re-work the board. I've seen stuff like this on more than a few production boards. \$\endgroup\$ Commented Nov 6, 2019 at 21:59
    \$\begingroup\$ I think when they say "hole" they are referring to the copper damage, not the real physical hole. But yeah, looks like someone made a mistake and tried to fix the board to cover their asses. \$\endgroup\$
    – Henrique
    Commented Nov 7, 2019 at 19:16
    \$\begingroup\$ You faked this... Those are jumpers wires on the board after some one damaged the circuit by using a large screw to close the control up and it was to big damaging the board.. No factory would do this as a repair because boards are cheap in factory and it would be less work than jumpers.... \$\endgroup\$
    – Bob
    Commented Nov 8, 2019 at 22:21
  • \$\begingroup\$ Looks to me like a rather badly-done mod of some kind. Maybe for competitive reasons to duplicate a key or something. \$\endgroup\$ Commented Nov 10, 2019 at 5:05
5 Answers 5
26
It's unlikely.
  • The hole is very nearly circular, and has smooth edges, indicating the hole was deliberately drilled.
  • Somebody has added thin wires to try to repair the damage, indicating the defect was found and "repaired" before the product left the factory.
Most likely the hole is meant for mounting the board into the housing. The damage to the surface layers is a fabrication defect that they tried to fix rather than scrapping the board.
Edit: As pointed out in comments, another possibility is that the hole was drilled deliberately to remove some incorrectly designed wires, and then the added wires you see were added to replace the connections broken by the drill.
  • 16
    \$\begingroup\$ Most likely the hole was the result of drilling out an internal short circuit. But I'm surprised that they bothered to fix it at all, rather than simply scrapping it. \$\endgroup\$
    – Dave Tweed
    Commented Nov 7, 2019 at 13:29
    \$\begingroup\$ @DaveTweed when labour is cheaper than a PCB, things happen \$\endgroup\$
    – Christian
    Commented Nov 8, 2019 at 12:30
20
Those wires you see aren't the bonded copper traces, which you think are left behind from the corrosion. They are wires added after the fact to correct the broken board. You can tell by the blobs of solder that were manually added, like the blob above the carbon trace that is not perfect (unlike what you see from wave soldering), or the solder added to the trace above that (north west of your red X), which you would never see on a etched board.
Considering that holes are normally drilled after most of the board is done in a typical PCB fabrication, and if it was a one off problem that would have been pitched, this is likely one of MANY boards that look exactly like this. The cost benefit of ditching these and a second run probably exceeded the cost of having these reworked manually. Material is more expensive than labor over there. The source issue was likely fixed before the next batch, but retooling a manufacturing process is also expensive, so who knows.
As to how that happened, speculation but:
  • Drill was too big for the material OR
  • the wrong bit was mounted OR
  • the speed/torque was set wrong, so it chewed up the PCB material OR
  • the depth was off so the collet holding the drill bit crushed the board OR
  • Questionable material. Material is cheap, Labor is cheaper, but that leads to quality issues.
Corrosion does not make perfectly round holes in PCBs... The edges of the hole kinda look like a crater, soldermask and tracks have been ripped off like someone hacked at it with an x-acto knife.
There are several copper wires soldered across the hole...
This looks like a very "ghetto" botched repair job.
Now, what does the virgin PCB looks like? A bit of internet search and...
There doesn't seem to be anything in the area of the hole that would blow up and then require someone to fix the damage, like a tantalum capacitor. Also, an important detail is that there is no hole on the original board.
So, where does the hole come from?
Now, the edges of the hole are really destroyed. This wasn't done by drilling. It looks like it has exploded.
I'm going to go with the hypothesis that this controller was shot with a .22LR bullet from the back of the board (referring to your photo), then refurbished. Please check if the diameter of the hole is the same as a .22 bullet, I'd really like to know!
  • \$\begingroup\$ The diameter is around 4.5mm so more like caliber .17 \$\endgroup\$
    – ahendwh2
    Commented Nov 6, 2019 at 22:41
  • \$\begingroup\$ Does the other side of the board look like it exploded too? \$\endgroup\$
    – bobflux
    Commented Nov 6, 2019 at 22:53
    \$\begingroup\$ The hole in the material (FR4?) looks awfully round for a .22 shot, I'd expect more jagged edges, if it would puncture the board at all. \$\endgroup\$
    – Mast
    Commented Nov 7, 2019 at 14:26
    \$\begingroup\$ looks like tear out to me, which is perfectly possible with a drill, \$\endgroup\$ Commented Nov 7, 2019 at 17:44
    \$\begingroup\$ The "healthy" PCB shown in your answer has enough differences from the PCB pictured in the question to make it obvious that they're not the same PCB design. \$\endgroup\$
    – Ross Ridge
    Commented Nov 7, 2019 at 20:48
It is a reject board that had a hole punched in it before scraping to prevent reuse. However some company (probably in the electronics recycling industry) figured since the boards were basically free the cost of the bare minimum repairs would turn a reasonable profit in the off brand controller market. This happens more often then most people realize. This is why some manufacturers have gone the extra step of punching/drilling holes or a quick saw cut into the reject parts to hopefully prevent another company from offering a comparable product at a lower price. They will already have lost the sale by the time your x button stops working and you realize you saved a few bucks to literally buy remanufactured garbage.
As others have mention - this is not corrosive damage and those wires were put on after the fact to attempt to hide the mistake. As to how the hole actually got there...
You can see that board was assembled before the hole was created. Check the edges of the hole - the solder points are all intact along with some of the underlying board. enter image description here
If it was broken during manufacturing of the board, the solder wouldn't be nice and perfect like that. Adding those solder points is usually one of the last steps in manufacturing. In fact, it would should have been rejected in QA and not made it to solder flow.
My guess is someone messed up and broke the board during final assembly and this was their attempt to correct the issue by hand. Others have pointed out that this hole isn't on a "typical" xbox one controller board, but you didn't provide information as to the brand to properly verify how it should look.
Did you buy this secondhand? If so, it is also possible that someone took it apart to look at it, messed it up and then tried to cover it up. Though generally if someone does that it's just kind of left there since no one will see it.
