How does a darlington pair work?
I am curious about how the second transistor sustains the current Ie
of the first transistor.
Why is the base not damaged despite this high current?
If the first transistor is over-saturated with high base current, then \$I_{b2} = (\beta_1+1) I_{b1}\$ doesn't hold anymore, it will be: \$I_{b2} > (\beta_1+1) I_{b1}\$.
The second transistor will decide its base current \$I_{b2}\$ in darlington. Say, if the max current passing through the emitter side of the second transistor is \$I_{c2max}\$, the max base current to the second transistor will be \$I_{b2max}=I_{c2max}/\beta_2\$, as it will be in active mode.
