I bought a 2 pole 6 pin On/Off/On toggle switch that's for DC power, (25A 12V)
see here:
Toggle Switch
The only issue is that I have no idea how to wire it, as mentioned, it has labels on the back, 1, 2, 3, 4, 5, 6 with no indication of what's positive and negative.
What I would like to do with it, is connect two power sources, and a main device, is that even possible with this switch?
Basically, I have a Monitor that takes 12V DC, and I want to use, USB-C (Which is converted to 12V through a buck converter) and a DC power adapter, but the switch is used to switch between them, so flicking to the first On will use USB-C, and then the second On will use the adapter, again, is it even possible to do that with this switch? If it is, could anyone help me with wiring? Because there isn't any schematics or diagrams that explain how this switch is wired.
Thanks in advance.
