I'm designing a circuit (guitar effect) and have reached a point where I have to switch the signal path between 3 configurations involving a pair of diodes.
The circuit's 'out' path has the option of going:
  1. Straight out (uninterrupted)
  2. Through a pair of parallel diodes (symmetrical clipping diodes)
  3. Via one end of the diode pair, with the other going to ground
I have a dual pole on-off-on switch that I would like to use if possible. The schematic currently looks like this:
Is it possible to switch between these three with a simple switch or will I have to use a rotary switch?
As requested, the three I would like to achieve:
CONFIG 1
CONFIG 2 (note diodes must be NC)
AND CONFIG 3
  • \$\begingroup\$ What does "through a pair of parallel diodes" mean? Normally one end of your D1-D2 pair would be connected to ground so you'd be running "across" the diodes. You could make your question much clearer by adding a schematic (without the switch) showing the three configurations. \$\endgroup\$
    – Transistor
    Commented Dec 19, 2017 at 22:45
Figure 1. Parallel connection of 0, 1 or 2 diodes across audio signal using a 2-pole ON-OFF-ON switch. (CircuitLab doesn't have a suitable symbol.)
Update after images posted.
Figure 2. Bypass, series and parallel diode switching.
  • \$\begingroup\$ This wouldn't work as it only connects one diode to ground at a time. I have now added images to show what I need. \$\endgroup\$
    – TCassa
    Commented Dec 19, 2017 at 23:02
  • \$\begingroup\$ You're right. D1 should be wired to both contacts of the first pole of the switch. Fixed. \$\endgroup\$
    – Transistor
    Commented Dec 19, 2017 at 23:05
    \$\begingroup\$ @TCassa: See the update. \$\endgroup\$
    – Transistor
    Commented Dec 20, 2017 at 7:10
  • \$\begingroup\$ Thanks - I had considered using an additional diode pair but was trying to avoid. This would work though. \$\endgroup\$
    – TCassa
    Commented Dec 20, 2017 at 9:34
