I am using LT3748 for Flyback converter design. In datasheet (https://www.analog.com/media/en/technical-documentation/data-sheets/3748fb.pdf), given formula for Rsns value (pg 21) is Rsns=100mV/Ilim, Ilim being the desired maximum output current. Instructions for Rsns selection are given on pg17.
For 2A max output current, Rsns should be 100mV/2A = 0.05R. My problem is that I can't figure out what is the min power rating I need for resistor (I have 330mW power rated resistors that I would like to use).
