Trying to retrofit an old Peltier wine cooler and I a question about the wattage and heat calculations.
If I have a 12V power source (switched) so the maximum Wattage it can convert to heat is (105W)
If I were to connect some sort of cooling system capable of dissipating 120W of heat (such as a CPU cooler)
Would that be adequate heat removal to allow the cool side to continue to decrease the temperature to below ambient? Or have I oversimplified the heat movement calculations too far?
