I need to create a circuit which converts a pulse to very low voltage pulse (micro volts). This circuit output goes to an amplifier circuit. Right now, I created a circuit using a voltage divider and op-amp (AD8512) HERE IS THE LINK. So I can change the input amplitude and output amplitude varies. This circuit is working fine in actual hardware as well. This Circuit behaviour is fine:
input --> output
5V --> 151mV
2V --> 61mV
500mV --> 15mV
100mV --> 3.46mV
My pulse generator can not go below 100mV pulse but I need for example a few micro-volts for testing. I need to test circuit with a pulse having amplitude from 1uV to 1mV. Is there any better circuit for such kind of voltage change.
Update: Circuit input and output pictures added. R1 = 100KR and R2 = 100R
