I want to ask about wall adapter (switching) with 2.5mm jack let's assumed its label as 9V 2A. I saw many tutorial even some product use normal adapter (2.5mm jack) with BMS module to charge Li-ion cells. (for this function BMS just over voltage protect and balance for each cell) So BMS module it's self don't have function to control charging current.
Q1: What happen when load draw current more than 2A? (Will it perform constant current mode?)
Q2: Is it safe to use wall adapter to charge battery? (Can we consider current on label as charge current?)
