I need to build a device that has a motor which operates a hefty rotary disconnect switch. The switch is spring loaded in the On and Off positions and I know the operating torque requirement of the switch. The switch has an Aux contact so I can read the position of the switch at any time. I also want to be able to operate the switch manually when the motor is turned off. The motor only has to turn 90 degress back and forth to turn the switch On or Off. I intend to use a Geneva Mechanism between the motor and the switch. I don't know what type of motor is most suited for this project.
Thank you for the comments. What I'm really asking is do I choose a stepper motor, a servo motor, a DC motor (brushless or not?), gearmotor? I haven't worked with motors much - I do mostly embedded PIC stuff - so I'm just trying to pick a path to go down for this design.
? \$\endgroup\$
