I would like to use a 555 timer to operate a 12V heater which draws about 13 amperes.
Would using two MOSFETs in parallel connected to the 555 output be a good solution to improve output power compared to one MOSFET? I have a couple of 2SK1941 spare with a rating of 16A.
I was looking at this earlier.
- Would simply using one resistor from each MOSFET to the 555 with maximum 200mA output be ok?
- Should I have the 555 output trigger a transistor with a higher power rating to drive 2 MOSFETs?
- Is it going to be very complicated to split the load evenly between the MOSFETs?
