I've been studying power supplies and diodes, all books I've read discuss a great deal of things, but there's something I haven't found, and that is how to calculate how much current a bridge rectifier draws when it has its output filtered by a capacitor (and connected to a load).
Sedra/Smith's book mentions that since the filtering capacitor will work as a reservoir tank, the diodes will only conduct during a certain part of the input signal needed to fill back up the capacitor, the portion that the diode is conducting is referred to as "conduction angle" , dividing that conduction angle by 2 times pi, you get cycle percentage, or in other words what percentage of the cycle the diode is conducting.
This helps to determine what the text refers to Idmax and Idavg, which are the maximum and average currents through the diode during the period of time that the diode is conducting to charge up the capacitor.
So it basically means that the bigger the capacitor (the smaller the ripple voltage) the diode will conduct during a shorter period of time, and in that shorter period of time it will have to conduct more current (since it has less time to charge up the capacitor).
Those figures obtained by Idmax and Idavg, only tell you the current through the diode during the conduction intervals, which are useful to determine if certain diode will be able to withstand brief outbursts of current. What I need to know is how much total average current is going through the diodes, or in other words:
How can I calculate the current being drawn by the bridge rectifier (entire circuit) as it would be shown on a conventional DMM when measuring the current being drawn by the bridge, when its output is being filtered by a capacitor (and connected to a load)?
I've simulated several circuits and when measuring the current being drawn by the diode bridge is not equal to the current being drawn by the load, and that's to be expected since the diodes are not conducting all the time, but not being able to know how much current is being drawn at that point (between transformer secondaries and bridge rectifier) is keeping me from being able to determine the total current draw of the circuit, thus I'm not able to calculate the transformer's power rating needed to feed the circuit.
