What are the values of the two highlighted resistors?
Considering the brown band as tolerance and ignoring the first (black) band, I came to the conclusion that the values are 680 and 220 milliohms. Is that correct? Thanks.
Photo of PCB with two resistors highlighted
  • \$\begingroup\$ 0.68 and 0.11 more like. Unless you see red when I see brown. \$\endgroup\$
    Commented Aug 7, 2020 at 16:49
    \$\begingroup\$ I came to the conclusion that the values are 680 and 220 milliohms. Is that correct? correct. @AndyAka the one to the right has red stripes. At least my smartphone and PC monitor shows so. \$\endgroup\$ Commented Aug 7, 2020 at 16:53
  • \$\begingroup\$ I homed in and it looked more red than brown then. \$\endgroup\$
    Commented Aug 7, 2020 at 17:47
0.68\$\Omega\$ +/-1% and 0.22\$\Omega\$ +/-1%
Probably both 1/4-W.
