I am planning to make a dew heater for a camera lens to get rid of condensation, using resistors wired in parallel, then distributing them around the circumference of the lens. Diameter of lens: 65mm
Total power output: 6W
Power Supply(powerbank): 5V, 2A, 20Ah
Resistance for each resistor: 120 Ohm
Resistor power rating: 0.25W
Power output for each resistor: 0.21W
Number of resistor required: 29
I Will probably insulate the wire with tape, and wrap the resistors in cloth around the lens. Is 6W too much or sufficient for this use? Any suggestions? Thanks.
