I am using the LT3571 to convert 5v to 50v as the bias for a photoreceiver. Overall noise and stability are good, but above 3.5mA the voltage begins to drop. At 8mA I am down almost 5v.
Doing some quick calculations, 5v->50v gives ~90% duty cycle. Looking at the switch current limit at that duty cycle, it is 400mA. If I understand correctly, for ideal components I should be able to hit approximately (1-dutycycle)/2 times the peak current, or 20mA. I am running into trouble at less than 1/5th that value, so probably I am doing something wrong or misunderstanding.
Here is my circuit diagram:
and here is the circuit layout:
I apologize for the images, but the boost converter is stuck into a more complicated circuit with very little free area. I opted to put the output cap on the backside. This added vias but let me put the cap pad directly over the switching converter GND, so the loop area is very small. Most components are 0402. The board is 4 layers, with almost all components on the top, then GND, then PWR and finally the back signal layer which has the output cap. Should I have avoided the vias?
I tested with the current limiter set to 20mA and with it disabled and it made no difference.
My inductor is 10uH with < 350mOhm resistance and a saturation current of 1 amp. The converter is configured to run at 1 MHz. Not sure if these are ideal?
Any advice? I'm new to DC converters and not sure how to proceed.
Edit
I tested the power supply (0.07V total sag), and my decoupling seems fine (few 10s of mV p2p ripple under load measured at the device power pin).
Following suggestions here, I tried lowering the switching frequency 2.2-fold (450 kHz) while increasing the inductor size an equal amount (22uH). Unfortunately, the voltage droop into 10kOHm was identical to my original 1MHz/10uH circuit (0.9V). I took a few simple measurements putting a scope probe on the switch/inductor trace (at 450 kHz/22uH):
Under load it seems the switching frequency becomes irregular, with some missing cycles, and a few that seem to happen too close together (?).
