Is there a distinct advantage to higher or lower voltage in a 12 V system?
In other words, is it better to run the system at one end or the other of the voltage tolerance: 10.8 V vs 15 V?
I specifically ask because I have both 24 V and 12 V systems on my boat. The 12 V systems consist of mostly lights, navigation equipment like GPS and VHF radio and water pumps. I achieve the 12 V system voltage by way of a DC-DC converter adjustable from 10-15 V. I have had it set to 14.5 V so far, as most of my equipment state they can tolerate a wide range in voltage. However, I was setting it high as it makes my water pumps run faster, which, in the case of my freshwater maker, yields faster fresh water output.
The drawback is that some of my cheap LEDs were failing. But they are not important and their wellbeing is not worth much in the big picture.
This makes me wonder if the slight increase in water production is a false economy if the rest of the system is less efficient at this voltage - for example, the LEDs.
I’m sure it is a wildly-complicated subject but, broadly, what voltage should I set things to? My primary goal is longevity and efficiency.
