When using a common cathode 7-segment display, is there a reason that two resistors can't be used to connect the two cathode pins to GND instead of using seven resistors to connect the seven anode pins to VDD?
I'm assuming there's a good reason, because I haven't been able to find any schematics that do it this way, but I'm unsure of why this would not work?
