I'm currently doing a project that consists of testing bio-implants to see if they are still good to use.
For this, I have to measure the impedance of the implant from frequency starting at 10Hz to 1MHz.
I'm using an L432KC from STM to control an AD9833 which outputs the 0.6ppV sien wave at the desired frequency.
The implants can have an impedance from a few ohms to around 100 kohm.
Applying this voltage to the implants will generate current and with Ohm's law, I can find the impedance of the implant at each point.
To do the operation, I need to convert the current to voltage so the 12bit ADC of the L432KC can read it.
Here's a "schematic":
I have struggled doing this conversion. I'm trying to use a transimpedance amplifier but I can only use it with low impedance measurements or high impedance. I can't size it for both:
Does anyone have a solution to have the biggest range in terms of resistance?
Am I maybe going about this in the wrong way?
