I'd like to use a standard 6v/3w bike bottle dynamo to power a 18650 battery charging module TP4056 which also powers some LED's.
Diode bridge rectifier steals 1.4v from the generator. In addition to reduced output voltage, a large portion of period would be without any current (all the time while absolute value of voltage is under 1.4v).
So, could I reduce this inconvenience by attaching a transformer right after generator, to multiply voltage by 4 and attaching output of the transformer to the diode bridge and on to the battery charger?
Would the transformer losses be smaller than the loss of having to use only diode bridge? Which kind of transformer would fit this purpose?
