Lets consider the following code, I want to make the b x for #2 whenever a changes
module test();
reg [3:0] a;
initial
begin
    $vcdpluson();
    a <=0;
    #5
    a <= 1;
    #5
    a <= 2;
    #1
    a <= 3;
    #4
    a <= 5;
end
reg [3:0] b;
always @(a)
begin
    b = 3'bx;
    b = #2 a;
end
endmodule
I am getting the following waveform from simulation
When a changes from 1->2 and 2->3, I expect the always block to get triggered(since the sensitivity list has only a). after #2 from 2->3 transition b should have become 3. But looks like after #1 b has become 3, it means the always @(a) loop didn't get triggered for the 2->3 transition of a. How to enable that ?
  • \$\begingroup\$ You have to post complete waveform with signal names, not a part of it. \$\endgroup\$
    – Mitu Raj
    Commented May 7, 2021 at 12:38
Your problem is you are using blocking assignments to write to b. That means your always @a procedure gets blocked for 2 time units before its able to see the next change on a.
By using a non-blocking assignment, the assignment gets queued, and the always procedure immediately goes back to the top waiting for the next change on a
always @(*)
begin
    b <= 3'bx;
    b <= #2 a;
end
  • \$\begingroup\$ even if you use non blocking statement it wont work \$\endgroup\$
    – arun
    Commented May 11, 2021 at 5:44
  • \$\begingroup\$ What's the meaning of 'won't work'? , are the waveforms exactly the same? You haven't edited your question to include more details on waveforms after and before changes made to the code.@arun \$\endgroup\$
    – Mitu Raj
    Commented May 11, 2021 at 7:25
